sunbird euro 190
Leon heims
i have a johnson 90hp with 4 plugs. should i use 2 stroke oil or 4 stroke oil , im not shure which one i should use. thanks
tashasdaddy
Re: sunbird euro 190
any oil rated TC-W3 outboard oil. walmart "super tech" is as good as any.
JB
WAIT!!
Give us the model number. Johnson 90s have come in both 2 stroke and 4 stroke versions and both use 4 spark plugs.
Then buy an Owner's Manual or you are sure to destroy your engine.
GeneH
JB has it exactly right! Get an owner's manual for sure and a service manual if you plan to work on your engine. Suzuki made a 90 4 stroke which I believe had the plugs all in a row top to bottom and it was Johnson badged. If you have two plugs on each side of the rear and a v-style engine, it should be a two stroke cycle engine. Put up a model # and get a manual or manuals factory only, no after market junk.
Leon heims
its a johnson 90 omc. quiterider. it has 2 plugs on each side of the rear. thankyou
JB
Okay. Whew!!
Tashasdaddy's advice is right on then.
