prop for holeshot
letsgo19
I have a 20ft bowrider with a merc 305 220hp we usually have 6 or 7 people and about 700lbs ballast for boarding i put a 18p 4 blade stainless prop on for holeshot but it is a little sluggish.Would i be better off with a lower pitch or a 5 blade?
ENSIGN
Re: prop for holeshot
To be serious,Ya need a bigger boat
steelespike
about 1800lbs of people and ballast I think I'd feel sluggish too.
I think prop selection would depend on your present rpm.Do you have trim tabs.
letsgo19
no i dont have trim tabs but i did notice that if i trim up a little before accelerating it improves take off alot.I assume its because there is less hull surface makeing contact with water meaning less drag.
Ayuh,.... I would think that with 7 people onboard, you otta be leaving the 700lbs of ballast on shore...
letsgo19
boat is rated for 9 people plus 200 lbs gear .Then one person gets out to board so thats a little less in boat when boarding.
Ayuh,... It's Still a 20' boat...
9x 150= 1350lbs. + 200= 1550lbs....
How heavy are your 7 friends,..??
My waGuess is, you're Overloaded by a 1/4 Ton....
letsgo19
One gets out to board i know its maxing out but other than the sluggish issue on takeoff it performs fine
hwsiii
You don't mention anywhere how many RPM you get at WOT, what are they.
H
steelespike
Not knowing what your rpm is could be hard on your motor.It isn't likely to be overeving with the load your pushing but you could be lugging it.To low an rpm max.
If the motor can't reach its rated rpm it is lugging through the entitre rpm range.
Sort of like forcing your car to tow up hill in overdrive.Only the boat is doing it all the time.
MTribe08
What type of boat is this, and are you using a tower to board with?
