nola mike
- Apr 22, 2009
- 5,997
so i got a replacement alpha 1 outdrive after my upper gearset disintegrated after getting water in the drive. "new" drive had some milky oil in there interspersed with good-looking oil. i just removed the lower drive to replace the water pump (glad i did--impeller looked rough). a couple of questions:
1. there was water between the lower pump housing and the blue seal (see pic). doesn't seem like that should be the case, right? what is that seal, and how do i remove/replace it?
2. there looks like there should be a small o-ring on the drive shaft, which i don't see. is it possible that this wasn't replaced at some point, or is it hiding in the upper case somewhere?
3. the kit came with 4 large o-rings. i see a use for one of them beneath the lower pump housing--are the others extra, or do they replace something i'm not seeing?
4. kind of stupid, but i don't see where the gear oil communicates between the upper and lower housings.
5. other seals that should be replaced before i put this back together?
