bamafutbal
- Sep 15, 2007
- 228
wanting to buy a cheap little fishing boat and the ad reads boat looks great and the 40hp mariner runs great but has a small hole in the manifold. i am asking for a little education before i go visit the boat this weekend. i am familiar with my manifolds/risers etc on my 2001 sea ray with a chevy 305, but totally uneducated on the outboards. is this an expensive fix, is the motor trashed if it has overheated, is it a good sign if it cranks right up and has a smooth idle and smooth rev, and where is the oil to look at to see if its milky or clear. anything else??? need help
finally talked to the owner, he said that he bought it that way (not knowing)last year, he had it checked out and the mechanic said that when the water pump was replaced, it punched a little hole in the manifold or that's what it looks like. the mechanic said its a difficult part to replace but since it has no load on it, just weld a peice of aluminum on it and it would be good to go. he said compression is 120 on all cylinders and will test it for me as well as put muffs on it or take it to the lake.
