JustJason
Thread starter- Joined
- Aug 27, 2007
- 5,394
Whoever invented the reverse face dial indicator needs to be shot.
I have this old 1970 ariens snothro that i'm fixing for a neighbor for FREE(well a case of beer... but it might as well be free). It needed a myriad of work. It's a single cylinder points based ignition system (since it's a 1 banger, and it only runs at 3500rpm, there is no reason on earth why this thing shouldn't have a simple external magneto ignition coil... but nooooooo)
So you have to set the point gap first, and then set the fixed advance on the timer base. Because this is an L head, you have to pull the head and set up a dial indicator on the piston. Find 0TDC yadda yadda. Well I have the service manual thats so old it might as well be written in 1776 by Ben Friggen Franklin himself. It's not the easiest thing to read, and the pictures are worse, and this is the first time i'm performing this procedure on this type of engine.
So anyways, the good book calls for finding 0, rotating in reverse .010 past the spec of .080 BTDC, then rotating forwards .010 to get to spec. This is done to eliminate "crankshaft play". Yeah... real precision stuff. After you set the pist to .080BTDC you need to rotate the timer base so the points just break. Sounds easy enough right?
I'm sitting here scratching my head, and my arse as to why I can't get the dang procedure to work.
I'm reading reading reading... doing doing doing. It isn't happening.
I'm going nuts.
I say to myself... either the procedure is wrong in the manual (wouldn't be the first time for things like that) or I must be missing something here.
I know how to use my dial and my meter and my feeler gauges, so i'm confident its not that.... or am I???
Then it friggen hits me.
In the manual they are using a reverse rotation dial. So .090 would be to the right of 0, and .010 would be to the left. I have a standard rotation dial. On mine .010 is to the right of 0, and .090 would be to the left.
In the manual it says after finding 0, turn the crank CCW until .090 is displayed on the dial, then turn CW until .080 is on the dial. The CCW and CW rotations were backwards for me. On top of that, to get it timed I had to go CCW until it was .010 on MY dial, then foward to .020 to get the thing timed to 80 thousands before top dead center.
Whoever invented the reverse face dial needs to be shot!!!
I'm going nuts.
