Compression ????
LAMudbug
Just wondering what the compression psi should be on a 155 hp evinrude. Done a check they all tested a 79 80 and 81.
jonesg
Re: Compression ????
Try a seafoam decarb treatment, see the faq files for the method, I just spray it right into the cylinder and run it, my compression came up 10psi.
Seafoam dissolves carbon on the piston rings.
But 80 psi is ok on big V6's.
2 strokes need to be decarbed every season, if enough carbon builds up the piston rings can get stuck and snap off on the port edges.
tashasdaddy
is this a 55hp or 155hp???? off the top of my head i do not recall a 155.
emdsapmgr
OMC made a 155 in 1989-91 timeframe. It's a commercial model, which will have special components. Some of these models are made to run on a lower grade of fuel, so they may have somewhat lower compression than a normal consumer 150 model. I'd follow Jone's recommendation and do a decarb on the engine and see if the compression comes up any. If it doesn't change any, don't worry about it.
LAMudbug
Yes I had to call Evinrude. It is a 88 or 89 155 hp super V6 it is actually a non production Military model the model is an AM 155 A Couldnt find any info anywhere but a rep at Evinrude got a little info. According to them it is compatible with the late 80s commercial models. Did a Decarb but have not checked the compression since. I know I have to do a carb rebuild too. just taking it one thing at a time
