I have a 1995 Force 120 HP that has two blocks with broken reeds. Does anybody know if the blocks from a 1994 Force will interchange? The 1994 block part number 818108A has five petals with rounded ends. The 1995 block number 11645 has four petals with square ends. The 94 blocks will physically fit fine in the 1995 motor. The parts book shows that the 94 block 818108A is no longer available and calls for the 11645 as a replacement. The nice thing about the 94 and earlier block is that you can still buy replacement reeds for about $10 bucks each. Unfortunately, Mercury does not sell a replcement reed for the 1995 and later blocks. Instead they make you buy the entire block for about $80 bucks a crack. So if a 1995 block fits a 1994 engine, does that also mean the 1994 block will fit a 1995 engine? Are there any mixture/lean/rich issues?
