Thermostat replacement
lmannyr
Master Chief Petty Officer
Looking up the T-STAT parts for my 2000 5.7 carb. Are sierra parts just as good as the Mercruiser parts? Or go MERCRUiser ONLY?
27-530451 Gasket
27-806871 O-Ring
23-806922 Sleev (Mine was bent along the edges from PO causing a trickle leak around the T-stat housing.
807252T2 160*
Thanks!
lmannyr
Re: Thermostat replacement
What is the difference b/w these 2 gaskets?
27-47510
27-806871
Thanks!
zbnutcase
Most Sierra parts are good and a lot of them have OEM numbers on them. 'nutcase
Ayuh,... I use alotta Sierra parts,+ don't have any real Problems with 'em...
Without lookin',... Is 1 the gasket with the rivet,+ 1 not,..??
lmannyr
those are actually the o-rings and the pictures look the same on the mercruiserparts.com site. Just curious. thats all.
Polar_Bus
I've been told by long time boating friends who do a ton of repairs that Sierra and Mercruiser are exactly the same spec'd out parts.
