1989 johnson 120 runs 2500rpm at full throttle
Josh.R
Re: 1989 johnson 120 runs 2500rpm at full throttle
i used to have a a boat with that same motor on it i had a same issue and it came out to be the jets in the carbs were not properly tuned....
buggyman20
How can you tune the jets when they are fixed. They have no adjustment. Thanks all info helps.
bktheking
I believe you'd change the size of the jets, you'd physically change to a different jet.
buggyman20
I have a few days off. I am checking the coils and other parts I can with ohmmeter. Do you think 40 degree temps would affect the readings?
SparkieBoat
I check coils with a spark gap tester...under $10 at many auto parts store. It should get a blue streak across a 1/2 to 7/16" gap. 40 degrees should not affect anything.
buggyman20
I checked the coils with ohm meter. All was in specs according to shop manual. I did have a couple of plug wires that had to be bent a certain way to complete circuit. What type of plug wires do I need?
nymack66
Someone please correct me if I am wrong, I can't find anything that shows me this year 1989 V4 120 with a (CD4) has the SLOW feature installed.
I know for a fact my 87 140 v4 does NOT, plus no blocking diode..
Can someone verify if this operating temperature is acceptable for this motor? I thinking its 2 high but I no expert.
ezeke
Beginning with 1988 models, the big bore looper V4 120 and 140 have QuikStart and S.L.O.W incorporated in the newer powerpack part 0583489 now superseded to 584041. The last year for the older powerpack (0582262)on the V4 Looper was 1987.
buggyman20
According to the " CE " LOOP SERVICE MANUAL for 120-300 HP. The motor has the S.L.O.W. warning system. It limits the motor to 2500 rpms when the temp reaches 203 degrees. The engine must cool to 162 degrees and be stopped to reset. By the way the CE is for the engine year in the model number. And it does have blocking diode in the wiring harness.
nymack66
Thanks for the feedback Guy's, I was not sure now I know ...
buggyman20
I have checked the coils they check out ok. What would be your opinion if I get an orange or yellow spark instead of a blue spark? It is raining here so I can not check them today. Also would the power pack have a tendency to act up when it is hot and not when it is cold?
buggyman20
Just checked the spark with tester. All 4 wires put out a blue spark on the tester. Measured at 1/2 inch. Any ideas?
SparkieBoat
it could be an intermittent problem with one of the power packs..run it on the water until it starts to act up then test spark..
ezeke
There is only one powerpack on this engine.
SparkieBoat
roger that, could it still be a power pack issue??
buggyman20
For anyone out there. Does anybody have any experience with the Power coil or Charge Coil or Sensor Coil going out and what it caused the motor to do. These are the only things I have not checked because I do not have the correct equipment to check them. Thanks
buggyman20
Finally got it to the lake. I put new plugs in it. It gets out of the hole very well and runs good up to 3/4 throttle. About 4500 to 4800 rpms. When I opened it up full it started cutting out. When I backed off it smoothed out again. I tried this a couple of times and it did the same thing. Any ideas?
jonesg
I just read all the posts from #1, I don't see that you have yet to discover whether you have a fuel problem or ignition failure.
Run it til it acts up.
A timing light will show if its dropping spark under load,
hitting the choke will show if its fuel delivery ( if the rpm's pick up).
In the meantime, you rebuilt the carbs?
did you do a link and sync ?
