Volvo penta I.D.
1searay
I have a 1983 Bayliner with a penta 280 outdrive that is bad, I found a complete penta outdrive but the only numbers they can give me are 868130
and 1101586238 Is this a 270,280
I have a aq175a engine v-6 i am mating it with, I will have it shipped but only if it works for me. Thanks guys
muc
Re: Volvo penta I.D.
The numbers you posted are for the shield (transom plate)
Don't know what drive it was sold with.
Good Luck Muc
captmello
It should be easy to tell the difference between the 270 and 280 as the exhaust ports are very different looking. Your 280 has the narrow horizontal exhaust and the 270 has an upside down triangle exhaust with a rubber flapper in it.
It is more important to have the correct gear ratio. You need to know what engine the used drive was mated with.
Good Luck.
1searay
Would it matter if the outdrive is newer, Mine has a 1.61 ratio
captmello
How much newer?
they seemed to begin phasing out the 270 and 280 aroung 1985, but continued with the 275 and 285 for a couple more years along with the 290.
1.61 is the V-8 gear ratio which should be out there. V-8 's were commonly matched with the 280 going back to the mid 70s.
Do Not buy a drive with the wrong gear ratio!!!
Sorry I'm not any help when it comes to serial number.:rolleyes:
Don S
The number 868130 that you posted, is a spec number. As near as I can tell, that is for a drive with power trim, and probably in the SP model drives, much newer than what your original drive is.
Basically, it won't fit. The clamp ring on the upper gear box is probably different, and won't work on your transom shield, along with the H fork on the intermediate section of the drive is different. Plus a lot of other little things I don't remember.
A phone call to Volvo with the numbers of what you have and what you want to try to put on will be necessary to figure it out. There is nothing on the dealers online site to determine the older model serial and spec numbers.
A few pictures of the drive you are looking to buy would help a LOT !!!! in figuring out if it's usable or not.
BUt if it's the wrong gear ratio, it's all a waste of time anyway.
Ask the guy if the drive was from a 4 cylinder engine. If it was (as I suspect, a 131) then it won't work with your 175 engine.
1searay
He said it was early 90's but those are the only numbers he could find, Am waiting for pictures
1searay
Found a rebuilt 280 1983 model that was mated to a small block chevy 225hp , Will this bolt up to my 3.8 v-6 chevy without many modifications?
Don S
It might "Bolt Up" but it will have the wrong gear ratio. Therefore, poor results.
1searay
My ratio is 1.61 just like his, I thought that's what i needed
captmello
According to the Volvo website, the AQ175 did come with a 1.61 ratio drive. So, this latest drive you speak of should work as long as you do not have power/hydrolic trim.
Early 90s will not fit.
Hope it works out for you.:)
let us know what happens.
1searay
Struck out ! Has power tilt/trim will not work. Found a 280 same year as mine rebuilt, same ratio 1.61 mated to a v-8 called a volvo dealer, He said it should work just fine. Thanks
