Re: New Mercury EFI 150 Question??
Drain, clean fuel tank, flush lines, drain vapor separator.
Pull plugs, ground wires, squirt a small shot of 2 stroke oil in each plug hole, bar the motor over a few turns just to make sure everything turns freely.
Reinstall the plugs, fresh fuel, start it up bring idle up to @ 1800 and let it warm completely.
Careful, pay attention to P stream, it should start once the engine gets to temp, if the least bit suspect, change the impeller.
