Winterizing-HOW MUCH ANTIFREEZE?
enginesilo
I am wintering my Mercruiser 3.0 this year and was curious to know how much anti-freeze I should buy to winterize properly?
I plan to follow Don's winterize sticky post.
How many gallons will do it?
Bt Doctur
Re: Winterizing-HOW MUCH ANTIFREEZE?
About 3 should do it.2 for the block, 1 for the manifold.
a70eliminator
Sounds about right, my v-8 drains exactly 4-1/2 gals between the block and manifiolds. I just drain the water, block and manifolds have survived many Ohio winters.
JustJason
Actually... I did 4 3 liters last week. You'll use a little under 2 gallons. Make sure you buy the -100F stuff.
Ayuh,.... None if ya do it Right....
schankla
my 4.3 took a lil under 2 gallons in the block through the thermostat housing.
a70eliminator
I drain excatly 4-1/2 gals of lakewater from the heds and manifolds each year.
