fish 4 life
Thread starter- Joined
- Oct 3, 2009
- 90
I have a 1978 Evinrude 140 HP on a 1985 Ranger 335-V Comanche that I am having trouble getting out of the hole. I had the carbs rebuilt and the mechanic says the engine runs like a top. I am able to get out of the hole but only if me and my brother sit at the front of the boat while my father drives. Once the boat does get on plane, the boat does about 45 mph and goes great. I was using a 13 X 19 3 blade prop I also tried a 13 X 17 4 blade prop and the same thing was happening. I was told I should check the engine for Link & Sync the carbs, Making sure the carbs are opening horizontal, and pickup timing is correct. Check timer base, that it is not sticking part way, has to go all the way to the rubber stop, check Max advance and set if needed. I am not sure what all this means. Can anyone explain this more so a non-mechanic like myself can understand.
