1961 75hp temp question
Marioleonard
hey guys I was just wondering if I could hook up a temp gauge to the brown temp wire the comes from the block and I think is used for the waring light?
R.Johnson
Re: 1961 75hp temp question
No! That is just a make or break ground switch.
Willyclay
I installed an OMC water temperature gauge on my 1962 Johnson 75HP because the overheat light came on every time I used WOT. It required a separate wire to the sensor that came with the gauge kit. I'll check my parts bin and see if I can find the part number. Will post if successful. Good luck!
Marioleonard
how did you put the temp sensor in the motor or were did you put the sensor?
F_R
There are two types. But they should come with the gauge kit. Some are threaded for screwing into the block. But get the kind that goes under a head bolt and save yourself a lot of aggrivation.
Marioleonard
do you know were i can find them? I have a electric temp gauge but it had the screw in sensor. Thanks guys you guys are awsome.
Willyclay
Mine had the sensor that bolted onto the cylinder head cover. It was OMC Kit No. 173763. The gauge only was OMC p/n 173819. Sorry, but I do not have a p/n for the sensor. You might find one on eBay. FYI, I still have the two pages of installation instructions for this kit. I can scan them and send you a copy. If you are interested, send me a Private Message with your email address because the iboats.com forum does not support attachments. Good luck!
Marioleonard
do they sell the sensor here guys at iboats.com? I see that they have 1/4 and 3/8 temp sensors.
Willyclay
PM received and email with attachments sent. I believe all sensors "screw in" to something; either to the motor's water jacket OR, in my case, to the external mounting bracket. You could fabricate your own bracket and tap it for your sensor's threads. Look at the installation instructions I sent you and see if that answers some of your questions.
Marioleonard
hey thanks that is what I am goning to do make my own bracket and put my sensor against the haed cover. can you send me a pic of you sensor on your outboard? Is the sensor you have flat in the end that touches the head cover?
Willyclay
Sorry, unable to provide any pix because that motor was three boats ago! My best shot was the installation instructions. Maybe another member has one installed on their motor. Good luck!
Marioleonard
do you rember if the temp sensor was flat on the side that came in contact with the motor?
