First year of Alpha 1, Gen II,
WizeOne
...can you tell them apart visually and, gear ratio given are they directly interchangable with an '86 Alpha 1?
Re: First year of Alpha 1, Gen II,
Nope,... The Alpha 1, Gen.II is Not interchangable with Anything but itself....
I think they came out in 91...
The Lower off your 888 on the upper from the broken boat is still the Best way out....
TilliamWe
Banned
...can you tell them apart visually ?
Yes. The Alpha One Gen 2 has a larger skeg that has an angled trailing edge. The Gen One's skeg is smallish and the trailing edge is perfectly vertical.
