johnson 9.5
patreed
help;I have a johnson 9.5 sereal # c461955. What year would it be? It has had a tune up but it dosn,t perform well.like it is only runing at 1/2 throutle.What are the carb. adjustments for this engine?
JB
Re: johnson 9.5
Model number??
F_R
Re: johnson 9.5
Adjust the carburetor all you want to. It won't help. The adjustment knob is for idle mixture.
90% of 1/2 power is because it is running on 1/2 of the engine. In other words it is running on one cylinder. Check the compression, spark plugs, and ignition system.
The other 10% when it comes to a 9.5hp is inhaling smoke. If it runs correctly with the hood off, that's it. Also, a 9.5 won't run with the hood on in a barrel.
crxess
Re: johnson 9.5
Follow F_R's advice. Probably points need adjustment or replaced.
Also Get a carb kit and do a thorough cleaning/rebuild. High speed orifice may be restricted.
patreed
Re: johnson 9.5
the model #on the tag is no. 110. I had the engine in for a coplete tune up...coils,points,wires and plugs.and no improvment.
