Replacing VRO in 1985 70HP
klewis77
Need help. Found out my VRO unit on my 1985 70 Johnson is bad. I don't want to fork out the money for a new pump unless someboby knows where to get one cheap. What parts and steps are necessary to replace the vro with a regular fuel pump? By the way, the oil tank was already unhooked and I was pre-mixing oil. Parts and steps would be appreciative.
Daviet
Re: Replacing VRO in 1985 70HP
I can't help you on this one, don't have anything with VRO. You might try doing a search, I think there has been several posts on the subject.
tashasdaddy
BRP Part Number: 0438559
Description: FUEL PUMP AY
from kenmyfan.
I used a 3 connection pump from a 1982 Johnson 140hp. (so I was told)
1 connection from the main fuel (now premix) line.
1 connection to the motor fuel feed for the carbs.
1 connection from the VRO pulse fitting.
Right now the motor has never run sweeter or sounded better.
klewis77
Is that part number (0438559) going to work with my 70hp? Is there a certain size or type of pump I need? Also Where can I get one of the pumps? Where can I get the parts to rebuild my vro(fuel side) if I decide to do that? The new mechanical pump just sounds easier though....any other info appreciated!
