michaeli84
Thread starter- Joined
- May 26, 2009
- 80
I was trying to get a smooth idle on my 140 merc today and just couldnt get it smooth. Finally , it seemed like it wasnt firing on al cylinders. I began pulling off plug wires while the engine was running. 1 2 3 responded by running rough but when reconnected went back to normal. However, when i pulled #4 nothing happened. I pulled the plug out and checked it and it looked fine. I then turned the motor with the plug out to see if any water came out but none did. These plugs are only a year old what do you think caused this to happen? I took an old plug from the previous tune up cleaned it up and popped it in, reconnected the wire, fired it up, and began pulling wires again this time it stumbled when i pulled the wire off. I want to know how/why that plug went bad and if the engine will be ok. I got it to idle very smooth once i fixed that problem. What could have caused this to happen? Also, i pull the plugs and clean them after every 4 hours or so. I noticed that they are heavily carbon fouled everytime. The spark is strong and the mixture is not too rich and the only time i idle alot is when im warming up on routine starts during the week for maybe 10 min at a time just to keep everything lubed and moving. Is this normal? Should i not start it up every other day like i have? well thats all for now thank you guys for your help!
