OK, Y'all ask for it and here she is. This is my 1965 Starcraft Nassau, Picked her up with the trailer for $850.00. brought her home and tried to crank her up... Started sorting out the electrical, needed a sensor coil and got a deal on an engine while looking for used parts. The boat has a 1975 johnson 50hp and the deal engine was a 1976 johnson 55hp! with alot of the same parts and after sitting for four years cranked on the second pull ($225.00) Swapped some parts and stumbled onto the Iboats forumn about the same time
found out that the water pump was not working when I got her running. Seeing that I needed to pull the carbs to loosen the lower unit I ordered carb kits and pump parts. Got antsie waiting to save the money for parts (wife said I can't use "our" money for boat)(she's been here before) I rewired the boat,rebuilt the tilt and trim,and after reading all the posts from you Starcrafters I pulled up the floor Looks like I'm in for the long haul. Got the parts Wednesday and have rebuilt the carbs,Installed the water pump parts and waiting for the rain to end...
