michaeli84
Thread starter- Joined
- May 26, 2009
- 80
I recently was having truoble starting my boat. I had to put the throttle all the way down for it to start and then back off it so it wont over rev. I seen that when the throttle was in the neutral position the choke was closed. When i put the throotle lever all the way down it would open up just about 1/8 in and the engine would fire right up. So i took the choke off another carb i had (the same style of course) and swaped them. When i did it i put too much tension on the choke i guess. When i took the boat out i was trolling for about 30 min at 1100rpm. When i went to speed up it started bogging bad almost like it was missing when i gave it gas. I took it back in slowly and came home and took the choke apart and read the manual and put it back the right way. I pulled the spark plugs and they were black with carbon. i previously cleaned them befor this last run. I turned the mixture screw to try and lean it out a little but it dont seem to make a difference. After putting everything back the way it was now i have a rough idle and i cant get it to smooth out. I replaced the water seperater also cause it was overdue. However when i put it to throttle only and rev it up it is very smooth. What should i do to fix this problem. It had a full tune up this season and the carb was rebuilt 2 seasons ago i use startron in the gas sometimes and mrvel mystery oil some time but not together. Sorry it is so long i wanted to be detailed so you can be accurate with your input thank you mike.
