MadCityMike
Thread starter- Joined
- Jun 9, 2007
- 12
This is a 1972 65 hp to which I've added a tell tale to help diagnose an overheating problem. The water pump is new and seems to be pumping water well, but I'm still overheating. The tell-tale has a LOT of air coming out with the water spurting under considerable pressure and as it gets hotter it turns into mist and then just air. I'm guessing the air pressure gets to a point that the water pump can't push water up. The air coming out is not smokey like the exhaust. Does air pressure in the waterjacket mean bad head gasket? Cracked head or block? Something else? I took some pictures of it running because it has water coming out of places I'm not sure it's supposed to. I drew arrows in all of the places where water is coming out.
Port side: water stream coming out of the front just above the cavitation plate which I believe is normal, but a lot of water is coming from where it mounts to the hinge. Also quite a bit coming from the base of the exhaust adapter. I took off the shroud to see if water was coming from somewhere else and just coming out there, but as you can see, it's just the front.
Rear view: You can see water streaming out of both sides of the hinge mount. Also, you can see the mist coming from the telltale.
Starboard side: Pretty much a mirror image of the port side with the tell tale as well.
I haven't had this motor long enough to know if water is supposed to be coming out of all of those places or not. It does run very good other then when it's overheating.
