swampy2646
Thread starter- Joined
- Sep 19, 2009
- 67
ok this senerio has been posted on here many times before.....i rebuilt a new long block it ran fine. last week boat sputtered and died. figured i was a victim of ethenol. at some points the boat started but ran like ****...stalling, wouldn't take a load, dumping fuel like crazy. figured the needle seat went, but when beched tested carb (sorry to say q-jet) at 10 psi, held fine. cleaned filters, even put a new mechanical fuel pump on. now problem seems to be ignition. no, or very little spark comong from coil. did the whole flow chart thing, by-passed instruments, ignition switch, laynard, shift interupter,tried a new sensor, tried a new ignition mod. swapped out coil, probed modoule harness for continuity, every thing shows voltage. even did a compression test all good. any ideas????
