175 Evinrude to 200 Johnson swap
mafhuntfish
Hi all - I'm about to swap out a 1988 175 Evinrude (e175tlccm) with a 1999 Johnson 200 (j200pleen). The guy I got the 200 from told me that the Evinrude controls will work with this motor if I buy an adapter? for about $35 from a Johnson dealer. Before I get into this - does anybody have an idea what he's talking about? TIA for any help .....
tashasdaddy
Re: 175 Evinrude to 200 Johnson swap
they throttle and shift cables will work, Just plug and play. the wiring harnesses ends are different, the 88 has a single big red plug, the 99 has multiple plugs. the adapters is a "pigtail" one side has the big red plug, the other the multiple plugs. besure to get the correct adapter. as there are 2 one that convert older control to newer motor, and new control to older motor.
this is what you need.
http://cgi.ebay.com/ebaymotors/John...-423-6349_W0QQitemZ110390032837QQcmdZViewItem
mafhuntfish
EXCELLENT information - I thought it would be something like that ... so much for the $35 - had a feeling that quote wasn't right ... I hope I have the opportunity to help others in the future as much as you've helped me .. Thanks Again
