Workin' on an old Tractor
captmello
This tractor we've got is mid 50'ish four cylinder gas engine. It starts and idles great but when you increase the throttle it starts to miss and sounds terrible. Its a positive ground electrical setup.
Anyway, We've recently had the carb rebuilt and flushed the gas tank. New fuel line. No fuel delivery issues.
I was thinking it may be the timing advance. It has a mechanical advance I believe. Shouldn't I be able to turn the rotor a bit and it should spring back?
mla2ofus
Re: Workin' on an old Tractor
A little info, like what make of tractor would probably help.
Mike
captmello
Mike
Well, its a White. Also known as Oliver or Cockshutt I've been told.
Don't know model, or anything about it really. We also replaced the points, condenser, cap, rotor by crossreferencing the distributor number.
Delco-Remy.
EddiePetty
...you didn't mention whether this was a distributor or magneto equipted engine. Either way, both have breaker points and a mechanical advance.
Head on over to Yesterdays Tractors and join the discussion group for you tractor. All the tractor experts live over there !!! (http://www.ytmag.com/cgi-bin/boards.cgi)
Ed in 'ol Virginny
'44 Farmall "A"
'44 Farmall "B"
'49 Farmall "C"
'48 Allis Chalmers "C"
'79 Wellcraft V-20 StepLift
'96 StumpKnocker
ThumbPkr
It sounds like a vaccuum leak,also check the plug gap before you get too deep into it.I just have a feeling that it is still a fuel issue.The float level in the carburator is another consideration.Good luck with it.Ron G
rbh
have had similair problem on old case la, the magneto cap had a crack, get a squirt bottle and put it on fine spray and squirt the top of magneto, you may see sparks.:)
rob
dolluper
Play with the point gap or look at a bad coil
captmello
Ed in 'ol Virginny
'44 Farmall "A"
'44 Farmall "B"
'49 Farmall "C"
'96 StumpKnocker
Ed,
That is a great tractor site!! Lots of info.:D
BTW, My buddies got an old Allis "C". Cute little tractor.
