92 johnson tracker!
jon_lee
I have a 1992 johnson tracker 40hp, and the plate that goes in front of the carbs is missing. does anybody know were i can get another one? will the motor run poorly without it?
Daviet
Re: 92 johnson tracker!
If you are talking about the air silencer, you can try a salvage yard or your local dealer. You can run without it, may make a little more noise.
jon_lee
its the cover that goes over the intake manifold, i think it is called a silencer i just found one online for like thirty bucs but thank you! another thing, the motor has a new tilt and trim motor on it or so the guy said anyways but when i hit the switch it wont pick the motor up. if i pick up on the motor then i can hear the tilt trying to work. what do you think? someone told me that it possibly needs new seals??
tashasdaddy
seals, low fluid. $30 not bad for a hard to get part.
