Re: Homemade oil draining idea
I like being able to see what comes out the very bottom...
so I use a hose in the drain plug hole like the one shown above. It will slide out through the drain hole in the transom, so I can just hang it out the back, take the cap off and let it drain into whatever. as far as oil filters... if easy to get to, do like anything else, if not, get a remote filter kit and hang it up where it's really easy to get to... imho...
I'm hard on stuff... and so I change my oil several times a season. I install a new high quality filter each time. I will run high quality oil - usually rotella T or others, for the first 50 hours or so and then switch to synthetic. mobile 1, redline or amsoil are the favorites. I have been running mobile one 20-50 lately. oil is a lot cheaper than engine rebuilds...
I also take the oil pressure off the front port in the block so you see what it is after the bearings... you can actualy see the idle pressure drop when the oil starts to lose it's viscosity. kinda scary...
