is a V-4 foot the same as a V-6???
SparkieBoat
I have a 89' 100 Johnson with a good foot and a 96' 150 Rude with a bad reverse. I was wondering if thetre was any difference in a V-4 foot and a V-6 foot.
Thanks Sparkie
wilde1j
Re: is a V-4 foot the same as a V-6???
Mostly, yes. The V6's typically have used a HD gearcase and the V4's a smaller gearcase, but a few V4's ('85 120/140 for example) have used the big gearcase.
jonesg
V4 commercial might be the same as V6.
SparkieBoat
so would you recommend me replacing the reverse gear??
Faztbullet
Hate to disagree but no, it will not fit as:(1) 1989 is a 3 5/8 dia gearcase (2) its a crossflow and driveshaft is different between a looper and crossflow(3)the early 120/140 and later V-4 "bigfoot" units will bolt up but gear ratios is different. So for a direct bolt up replacement the answer is no.
SparkieBoat
thanks Faz...now this is my first gear case rebuild..how do I get the shaft and hub out..I got all the bolts out..I think..Shaft will move up about 1" then stops.
Thanks Sparkie
wilde1j
You're using an OEM shop manual, right?
SparkieBoat
got one on order..just got the motor recently..manual should be in any day now
Faztbullet
On a 96 model just remove the 2 bolts and tabs that hold carrier in place and pull out. Measure the prop shaft as there are 2 different size reverse gears, tilt case and reverse will slip out.
SparkieBoat
Thanks Faz..there looks like 4 bolts holding the carrier and I do not see any tabs. Is that right???
Sparkie
SparkieBoat
Also I read somewhere that the shift rod height for a looper is different than a regular. I have a 1996 150 Intuder that says loop charged on the breather and spitfire series on the cowl. I have been unable to find a model # anywhere on the motor. So are the looper foots different then the regular ones??
The shift rod heights I read are 21 1/4 for regular V-6 and 21 15/16 on a looper. Also I will need to know how to know what parts to order for my foot.
So any advice on how to ID my engine/foot would be helpful.
Sparkie
SparkieBoat
ok I have done some checking ..it appears that because I have the 4 bolts as opposed to the 2 bolts and tabs..that I may have a V-4 foot on my motor..in which case I will not bother to fix it..but find a V-6 replacement.
Thanks Sparkie
Dhadley
How many splines are on the propshaft of the unit you have? 13 or 15?
SparkieBoat
15 splines on the prop shaft and 20 on the driveshaft. I am not sure about the year of my motor..previous owner said the guy he got it from said it was a 1996 150..all I know for sure is it is a V-6
Faztbullet
That a early style lower from used from 1979-1991, for it to have a looper shaft(1996) it will be in the 88-91 years as these had the 2 piece drive shafts.If it says Sitfire,Intruder its a 60 degree looper.
SparkieBoat
Faz ..can you tell me what LUs will work with my motor..I am guessing from your post that a 88'-91' V-6...I know where a 2001 150 fitch is with a rod through the block I can get cheap..would that LU work??
Thanks Sparkie
