470 exhaust manifold, looks okay?
natemoore
Master Chief Petty Officer
I pressure tested my manifold. There are no leaks. That's good.
You can see from these pictures that there is considerable erosion around the #4 cylinder mating surface, as compared to the #2, also shown.
The Quicksilver manifold is $900. An aftermarket company called GLM is going to start making these, and they'll retail at around $350, but they are at least a year away according to one of their distributors.
So, I think this manifold will work despite the thin gasket surface area, at least for a while. Hopefully, it will last until these GLMs are offered.
Can an adept aluminum welder add some metal to the eroded areas, or would this stress and crack manifold?
bruceb58
Re: 470 exhaust manifold, looks okay?
This is the mating surface between the manifold and the head right? There is no water passage here so not a big issue. As long as you don't have an exhaust gas leak there should be no danger of using these as is.
natemoore
Yes, manifold-cylinder head mating surface.
nimrod69
Stay away from GLM- very bad quality- Made in China, need I say more?
bruceb58
If you aren't getting an exhaust leak then you need not be worried. Its the riser manifold joint where you need to be worried about.
natemoore
Hey watch it! Every single one of my disposable power tools in my work trailer is made in China!:D
natemoore
There is a little erosion there, but it still looks okay to me. No one has answered the welding question, though.
Red RTV is from my pressure test, btw.
Link2052
Here is mine, 2003 4.3L port side exhaust riser spacer. after 6 years raw water cooled run in salt only and flushed with a flushing product for salt use.
When I split it apart I noticed the exhaust shutter was cracked I think this might have added in the breakdown of the cast at that surface.
took off other side and it was perfect .
Replaceing both riser spacers
