towrecovery
Thread starter- Joined
- Aug 27, 2009
- 10
I just bought a 9.8 110 to restore serial # 3451716 . I am having firing issues. Does anyone have a picture or the wring harness for this engine ? Also is there a way to test the red module that the high & low speed coils hook to ? Also is there a way to test the high & low speed coils ?
The problem I am having is this ..................
Only one cylinder will fire ( the top Cylinder ) I can unplug the + or the - wire on the top cylinder & the bottom cylinder will fire . However if I leave both cylinders hooked up on coils only the top cylinder will fire. I have took the point lead wire from bottom cylinder moved it to top cylinder coil , the top coil will fire .
I do not know what is going on here . I bought a clymer manual 3.5 to 40 hp 1972 to 1989 to obtain some function tests . I had no luck basically a lot of tear down information .
