I have restored a 19' dory which is performing wonderfully. However, I am having a devil of a time loading it on the trailer. The trailer has 10' bunks at the rear and keel rollers. The problem is that as I try to load it, either by driving it on or winching it, the flat hull at the stern shifts off center causing the deep vee bow to go out of line and scrape on the axles of the forward keel rollers. I have the feeling that there are some basics of loading a boat on a trailer that I am unaware of.
I installed a 12" centering keel roller at the rear of the trailer and put side bunks about four feet from the rear, but this is not helping. The original keel rollers on the trailer are on axles running through welded tabs. The are too low to accept side bells. I can shield the hull and cut them off with a torch, but I am not sure that is the answer. My beautiful new glass and epoxy over plywood hull is getting all gouged up.
Too deep, too shallow, trailer not configured or adjusted correctly??? I have tinkered with this problem a lot, but I am at a loss. I would greatly appreciate some advice.
Thank you.
Thank you.
