165 I6 backfiring thru carb under load
Steven D
Just got back from the lake for the first time with my 69 Sea Ray with 79 165 inline 6 transplant. All went well for the first hour, some stalling issues going from idle. The transision from idle to butterfly opening is rough and had to work a bit (feather the trottle, open and closing rapidly for the first little bit till it "caught") to get things going. Once up to speedit pulled very well and would top out around 37 and cruse at 30 nicely, all throttle settings seemed to be running well. Temp and oil pressure were all in the green the entire time...
Then about an hour in started having issues with backfire thru the carb under heavy load. I could cruse at around 10 MPH or so with no issues but any harder or on acceleration I get a loud backfire thru the carb on a regular basis. Idle went down as well, barely sustaining idle and applying throttle was very difficult without stalling. Got back to the dock and tried working with the idle with no success, original setting seemed to be the closest, any further on the idle screw and it died out.
Thoughts???
Thanks,
Steven
TowRoper
Re: 165 I6 backfiring thru carb under load
sounds to me you MAY have had a lean mix causing detonation? i myself would start with a compression test and if that looked good i would clean and maybe rebuild the carb.
proxyx
Banned
loose distributor screw (at the base) could set the timing way off... in a moment, your pattern fits here.
JustJason
Lean poppin through the carb is preigntion. 2 different things.
1rst. Make sure your engine is in tune and the timing is set and correctly advancing
2nd. Head up to the adults only (diy section) and perform the boat side fuel system test that I wrote. Make any repairs necessary along the way.
3rd. If it passes the fuel system test time to rebuild the carb. Or more than likely replace it being yours is 40 years old.
diehard
i would check your ingnition system pull your plugs and see if they are all fireing one bad plug or wire would cause popping under a load
mi19ch
I had the same problem at the 1st of the year. Fule filters were stopped up also check timeing.
