No Fire
jascot22
I changed out the switch boxes on my 150XR2. I checked everything I was told to check before changing out the boxes. Before I had fire on 1,3,5. Now there is no fire on any cylinder. I double checked the wires and all are in the right place.
Barnacle_Bill
Re: No Fire
Disconnect the black/yellow wire going to the boxes and then recheck. If you now have spark there is a problem with your kill circuit.
j_martin
Re: No Fire
Next step is to check the stator and trigger outputs with a DVA. If you were told to buy switchboxes without this test, you were mislead.
Accurate diagnostics are the best way to reduce parts costs.
hope it helps
John
