ctf58
- Aug 31, 2009
- 33
I just got a 1996 16? Stratos 258 with a Evinrude 70hp motor.
This boat came with a Sting Ray hydrofoil on it. I think the reason was because the previous owner and his son were both well over 275lbs each. I like the way I get on plane fast now, but, the boat leans to the left so bad on take off that it scares the crap out of my wife. When on plane it gets better as I trim up. When I get to the point of trimming up and it starts to porpoise I'll trim down to calm things down but there is still a noticeable lean to the left and the boat pulls to the right. If i allow the boat to turn to the right it levels out. I've really tried to make sure the boat is balanced. Same battery on each side, gas tank in center 2 people within 30 lbs one on each side. Could it be the hydrofoil? I measured it last night and it is dead cantered on the vent plate. The trim tab was move over so the rear of the tab was to the right a little so I move it to center and the boat pulled more to the right with the same lean issue.
The foil has a nick on the right tip and is missing about 1 inch along the trailing edge about 1/2 inch deep into the foil. I read about the smart tab but the money is not in my pocket right now and probably will not be until spring, plus i think my speedo and transducers are going to be in the spots for the tabs.
What do you guys think??
