115 johnson wont idle when trimmed down
Rabesreef
I have a 1997 115 johnson that wont idle when trimmed down. Replaced fuel pump. Also replaced primer bulb. Also the primer bulb never gets hard when pumped.
Bifflefan
Re: 115 johnson wont idle when trimmed down
Hold the primer with the arrow/or out end pointing up when you pump it. Its what the BRP dealer told me for my new one. And its the only way it works correctly.
As for the no idle when trimed down. Is the float level to high? Is there gas running out of the carbs when it running?
Rabesreef
No gas running out of the carbs. I should also mention motor runs great at top speed. Thanks
Bifflefan
When was the last carb rebuild?
these things are to quriky for me, I just take mine in to the dealer and say
"fix it". they do and everyone is happy....:D
Wosh i could help more.
Rabesreef
I just pointed the primer bulb up and just like you said it got hard. should i keep it mounted that way?
kenmyfam
Idling when trimmed down I have found is when the motor runs at it's slowest. I think due to the amount of motor submerged at that point. Have you tried setting the idle speed while the motor is running in this position and in gear while you are on the water ?? What RPM is it idling at when trimmed a little higher ??
Rabesreef
It just floods out immediately when trimming down.
