Outdrive Lock Nuts
krisnowicki
So I bought and outdrive and engine from a salavage yard to repower a liberator that had an omc package in it. The outdrive has a lock nut on it. like on you would see on a tire that prevents some on from stealing it. Well... are there marine versions of these or should I go to pep boys and compare it to those there? Any one have any experience getting these off?
Re: Outdrive Lock Nuts
Ayuh,... Weld a Big ole Nut to it,+ turn it Off....
Probably gotta use nickle or SSteel rod,... They're usually some form of SSteel...
I've also had Luck with Beating a 12pt socket onto 'em,+ being able to turn 'em Off...
It usually splits the socket, but the lock is Gone...
TowRoper
i got one off just using vise grips but im sure i just got lucky
krisnowicki
that is the one. It had the little rubber nipple and all... I tried vice grips and when I turn the outside it just spins and does not turn the nut. All I am worried about is ruining the threads maybe I will weld something to it. Thanks for the advice
Ayuh,... At Worst,.. You pull the stud from the housing,.... Big Deal...
krisnowicki
does the thread unscrew like a stud in a intake manifold? if so maybe I will pull the stud and replace it anyways... no torch or beatings need...
Ayuh,... Those are 6 Studs,.... Threaded on Both ends.....
Don S
Why don't you just order the lock and the tool. Then you don't damage the drive, or the stud. Plus, you can keep your outdrive from being stolen.
Dshow
I hope the mfg doesn't have more than one unlock tool pattern...
