Prop sizing
sgmjmd
I need correct prop for a 34' Sea Ray Sedan Bridge. Twin 350 merc cruiser inboards 260hp. Have 17 x 14 props but only turn app 3500 rpm. What is the correct prop to get rpm's up to app 4500 rpm
hwsiii
Re: Prop sizing
Sgm, you would need to change to an 11" pitch prop to reach 4,500 RPM. But that sure sounds like a very low pitch.
Prop Pitch
If you will fill this form out I will do an analysis and try to see what props you need.
Iboats Boat and Motor Info
1. Year, make and model of boat
2. Length, width and base weight of boat, look for boat decal on back of boat
2a.What is the maximum recommended HP for your boat
3. Number of people and gallons of gas normally on boat
4. What do you use the boat for
5. Is it a Deep Vee and if so how many degrees of deadrise
6. Year, make. manufacturer and model of motor
7. HP and gear ratio of motor IMPORTANT
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape a c ross the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene
10. Is it a bass boat or does it have a pad bottom
11. Does it have a hydrafoil, dolefin or trim tabs
12. Make, model, diameter, pitch and whether SS or aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50
RPM ___________ Speed ___________ No. of people ____________
14. Are you at sea level or a higher elevation, give us the elevation in feet
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
17. Does the prop show any damage that you can see
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
REMEMBER, The numbers I give you will be NO better than the information you give me
The only thing I ask of you is to come back and give me a report of WOT RPM and speed for my database.
H
sgmjmd
Re: Prop sizing
LCDR, I am still in the process of gathering information and testing. A friend and I are going to take the boat out and check out WOT and RPM of motors. This will take take place within the next 2 weeks. I had taken my porps to a prop service Tech and he thinks that they are the porps that should be on the Sea Ray Sedan Bridge.
hwsiii
Re: Prop sizing
That sounds good, let me know the results.
H
crxess
Re: Prop sizing
Hull condition?
Total load?
Stringers waterlogged?
Has it been hauled out and cleaned lately?
I have (2) sea rays, one is a 6000+ lb weekender with single 305(5400RPM WOT) off 14x17p prop.
I believe your prop size is correct and you have other issues that need to be resolved.
The harder it is to push the hull, the lower the Speed and RPM.
I would first weigh a truck/trailer at a local scale- load the boat and weigh again. Compare to Mfg. specs. Get a good starting point.
