chambers1517
Thread starter- Joined
- Aug 14, 2009
- 205
If you could have the same boat with a 5.7 carb or 5.0MPI, which would you take?
I've owned three 305's and many more 350's and I'd always rather have the 350 it's a much better design better block (may even be 4 bolt main) better heads ...
I'd say 350 with the carb.
Reliability should be the same, carbs can go many years trouble free. The mileage will be about the same also._chris_ said:5.0MPI = more reliability and better mileage and plenty of power for my needs.
They are basically the same block. One just has about 1/2" bigger bore.
I disagree with both, but I hate carbs . . . Just scan the I/O forums and the OB forums for Carb issues vs. EFI anything, OK forget the FICHT's, but the point is the same. When was the last time your EFI car had a fuel system issue? Anybody remember f'ng with carbs on their cars endlessly?Reliability should be the same, carbs can go many years trouble free. The mileage will be about the same also.
