I have a '70 25 hp Johnson with metal 6 gallon can. I am not getting fuel to the carbs using the bulb. I replaced the connector to the motor that was loose, but still nothing. Pumping the bulb does not do anything, am wondering if the bulb is the problem. What steps should i take to solve the problem?
second question - the vent on the gas can is on top of the gas fill cap. Should it be closed or open when trying to pump gas to the motor?
Thanks
CparkerC
Thanks
CparkerC
