Lower unit
rinker209
I was greasing my sterndrive and noticed a piece was broke off. I was wondering if it affects anything. Do I need to replace my lower unit. I have not taken it back out on the water yet to check if anything was affected. Any fixes I can do short of replacing the lower unit. I attached a pic the red arrow points to wear the it broke. The piece missing is about 1-2 inches long. What is this part of lower unit called? Could I have a piece of metal welded in it's place if needed. I have heard of people welding Skegs back together after they broke off.
Evinrude Boater
Re: Lower unit
It's the anti-cavitation plate. It keeps the prop from sucking down air. You know the sound when you turn too sharp and too fast and your motor revs up? That's cavitating. It probably won't make a difference if left. If you have the broken piece you could epoxy it or have it welded. Likely you would have to remove the seals and guts of the gear case to avoid damaging them when welding.
TowRoper
Re: Lower unit
thats the anti- cavitation plate Ive seen guys form jb weld to fix that and as far as Ive ever heard its a good cheap fix as long as its not broke so that water will get in:confused:
rinker209
Re: Lower unit
As far I can see there is not a crack through the lower unit.
rinker209
Re: Lower unit
Thanks guys for the quick response. I will inspect it closer in the A.M
jtybt
Re: Lower unit
Yup! Anti-ventilation plate. With a cracked in that area, you're likely to introduce air and ventilate the prop.
bigbrownbuku
Master Chief Petty Officer
Re: Lower unit
that area is more anti splash then any ventilate, you should be fine until you pull it for service in the fall. however if you notice more rpm and less speed chances are the prop is ventilating.
i dont move fast enough to cavitate tow roper, slow and steady wins the race.
TowRoper
Re: Lower unit
crap i did call it the wrong name...... take a stripe lol
rinker209
Re: Lower unit
So do you guys think I will need to replace or fix it. If i do not notice a high rpm at lower speeds I should be fine?
cr2k
Re: Lower unit
A welding shop should be able to tig on a piece with out hurting anything.
Probably won't cause any problems as it is.
rinker209
Re: Lower unit more pics
Here is my actual damage. Pisses me off. I am concerned with a chip. If you look on the last pic you will see a white dot, in the pic it is right above the break on the end. It's a decent chip can't tell if it goes all the way through the wall of the unit. How thick is wall of the unit? How can I tell if this chip/possible crack lets water in. I did not see anything coming out of chip. Does anyone know of a good Shop that can repair this break?
