TralierTrash
Thread starter- Joined
- Jun 21, 2007
- 12
I've been scanning these forums for a while and have some questions. With no avail I've sought help from multiple sources, which all lead to the same answers. I've tested what I have been instructed to test. Replaced parts and still have an issue that has no resolution.
Motor is a 1976 Johnson 55hp. There are about 30 hours on the motor. Freshwater use. Stored dry, in a dehumidified garage. This s pushing a 14' Fiberglass closed bow, runabout.
The engine runs great, does not overheat, pushes the boat at about 33mph.
The question about the motor pertains to voltage. Both on the dashboard Voltmeter and confirmed at the battery with a multimeter, with all other electric disconnected from the battery other than the motor, the voltage is normal at idle, but spikes to nearly 17 volts at running speed. This is a cause for concern. I was alerted to the problem after two starter solenoids failed. The cause of the failure was traced back to high voltage. I've tested cables for resistance and unless I haven't tested properly cannot find a defective battery cable or bad ground. The battery is new and rated above the minimum stated in the owners manual. I made the assumption that the voltage regulator/rectifier was defective so replaced it as a precaution. I retraced wiring and cannot find a fault ground or cable that is creating higher than normal resistance. I do not want to damage other expensive parts.
Any thoughts or recommendations would be sincerely appreciated.
