CaneCutter79
Thread starter- Joined
- May 24, 2009
- 454
Re: Prop/motor height setup
I thought about doing it that way but I was affraid I would damage the lower unit or skeg if the blocks shifted.
Definately do not block the bottom of the skeg right?
Also, since this is hydrollic trim, will the motor try to trim up vs. sliding up when raising the trailer jack up front? I had a 40hp motor do that to me without hydraulic trim when raising a motor on a jon boat.
Again, your responses are very much appreciated. I can't afford to break anything and I want to be well enough informed when doing things like this on my own. THANKS!
