200 johnson 1983 Carbs have different numbers
tajjf1
I have a 1983 200hp Johnson J200TXCTD Went to take apart carbs And each one has a tag on one screw I noticed the top and bottom had same numbers but the middle was different Whats this mean 393181 200 16FH middle one was 393182 200 31HH
bktheking
Re: 200 johnson 1983 Carbs have different numbers
Those are the OMC part numbers of the carbs for a 200, the top and bottom are the same part number while the middle is it's own number.
393181 x 2
393182 x 1
tajjf1
Ok so I guess my question now is do i have to buy different rebuild kits. they look the same.
bktheking
Possibly, I'm sure your omc dealer can point you in the right direction. You could always go to http://epc.brp.com and look it up.
emdsapmgr
The carbs all take the same rebuild kit 439076. The carbs are basically the same carb, the center one has a different part number because it has the roller and arm on it that contacts the throttle cam.
tajjf1
thanks for clearing that up for me
