Re: Quick Vaseline question
its called chalking :] , use fine sand paper then cut with wool pad and rolite ,then polish . repectfully rinsing constantly so as not to drive any oils[caugh] into the pores of the paint , actualy use a dewaxer before you start here is a list of ingrediants in vasiline ;
Ingredient Glossary
BORAGO OFFICINALIS SEED OIL
An emollient; specifically, a botanical oil rich in triglycerides (which are building blocks of skin lipids) and antioxidants (which are a part of nature's defense and repair mechanisms).
BUTYLENE GLYCOL
A humectant material that binds with water molecues and holds them in skin cells.
CAPRYLIC/CAPRIC TRIGLYCERIDE
An emollient; helps seak in moisture and gives your skin a smooth feel.
CARBOMER
A thickener; gives lotion a thick, rich feel.
CETYL ALCOHOL
An emulsifier; an ingredient that helps to hold the lotion together. These ingredients are what keep all the other ingredients blended together in a smooth, creamy product.
CLYCERYL STEARATE
CYCLOPENTASILOXANE
A silicone; gives lotion a smooth, skily feel.
DIMETHICONE
An occlusive emollient material made from silicone, dimethicone helps seal in moisture and gives your skin a smooth feel.
DISODIUM EDTA
A preservative; essential to keep lotion fresh every time you want to use it.
DISTEARLYDIMONIUM CHLORIDE
An emulsifier; an ingredient that helps to hold the lotion together. These ingredients are what keep all the other ingredients blended together in a smooth, creamy product This particular emulsifier iteracts with the skin surface to provide a silky skin feel.
DMDM HYDANTOIN
ETHYLENE BRASSYLATE
An odor neutralizer to help mask any unpleasant odors from certain essential ingredients. Because Intensive Rescue products are unfragranced, they do not hide their ingredients behind a wall of heavy perfume.
GLYCERIN
A humectant or "water magnet" that binds with water molecules and holds them in skin cells. Glycerin effectively replicates the role of your skin's own natural moisturizing factor.
GLYCERYL STEARATE
GLYCINE SOJA (SOYBEAN) STEROL
GLYCOL STEARATE
HELIANTHUS ANNUUS (SUNFLOWER) SEED OIL
HYDROXYETHYLCELLULOSE
ISOPROPYL ISOSTEARATE
An emollient and humectant; helps seak in moisture and gives your skin a smooth feel.
ISOPROPYL PALMITATE
An emollient; helps seal in moisture and gives your skin a smooth feel.
LACTIC ACID
An Alpha Hydroxy Acid that helps soften hard calloused skin.
LECITHIN
A natural phospholipid known to be an important component of healthy cell membranes.
LINOLEIC ACID
An essential fatty acid known to be a building block for skin ceramides (which are components of a healthy lipid barrier).
LINOLENIC ACID
An essential fatty acid that is a building block for skin ceramides (which are components of a healthy lipid barrier).
MAGNESIUM ALUMINUM SILICATE
A structurant (or a thickener) to give the lotion a rich, elegant consistency. Structurants add thickness to the formula without adding heaviness or stickiness to the lotion.
METHYLPARABEN
MINERAL OIL
PEG-100 STEARATE
PETROLATUM
Pure Vaseline Petroleum Jelly has been caring for skin over 130 years. It is an occlusive emollient that seals water within your skin and its cells. Petrolatum fills in for lost lipids to help restore skin's all-important barrier function - keeping the outside world out, and the moisture in.
PHENOXYETHANOL
POTASSIUM HYDROXIDE
A neutralizing agent used to maintain the pH of lotions.
POTASSIUM LACTATE
Used to maintain the pH of the AHA at an effective level.
PROPYLPARABEN
SODIUM CHLORIDE
Works with cationic emulsifer.
SODIUM HYDROXYPROPYL STARCH PHOSPHATE
STEARETH-21
STEARIC ACID
STEARYL STEARATE
TAPIOCA STARCH
A thickener; this particular thickener gives lotion a smooth, silky feel.
TITANIUM DIOXIDE
An opacifier that helps bring out the clean white color of the lotion.
TOCOPHERYL ACETATE (VITAMIN E ACETATE)
A material naturally found in skin as a natural anti-oxidant.
TRIETHANOLAMINE
WATER
Water is fundamentally essential to quickly restore the flexibility of your skin's dry surface layers, but it requires additional ingredients to keep it locked in.
XANTHAN GUM
