water pump gasket
rw21r
I just reicieved my water pump repair kit from iboats, there is only one paper gasket for the new metal plate, shouldn't there be two? one for the under the plate and one for between the plate and impeller housing? all the pictures only show one but my seloc manual says both should be replaced. I have a 1985 30 hp evinrude.
tashasdaddy
Re: water pump gasket
now you are find out why, we do not recommend a seloc manual, it is full of errors.
rw21r
soooo does that mean there isn't one below the plate?
CatTwentyTwo
The gasket goes below the plate, there is no gasket between the plate and impeller.
rw21r
thanks for clearing that up ryoung
