Re: Carb rebuild kit
The 074 jet is your maine fuel jet. The 058 jet is the air jet for the main fuel jet. Air is metered with the metered fuel to give the proper mixture for combustion.
The kit will contain a needle valve, needle valve seat, seat retainer, bowl gasket, bowl bolt gaskets, some screws for the plates, some blind plugs and a welch plug.
You only need to use the gaskets, needle valve, valve seat and the retainer if you lose the original.
The other kit contains the same thing but also a float.
John
