Older 75? HP Johnson around 1975 with no serial number and no peehole??
dcoon
I cannot find a peehole in this Johnson outboard that is above the water line. There appears to be one but it is in the front of the lower unit facing the transom and below the water line. Did Johnson Make an older outboard that did not have a visible pee hoile? Also, this motor has been painted and is reported to be a 75 HP but I cannot find a serial number anywhere. (I hope it was not a stolen motor!!) I just got it used a few weeks ago and would like some info.
wilde1j
Re: Older 75? HP Johnson around 1975 with no serial number and no peehole??
Some older motors have no tell tale. Not very important anyway. Hole in front of LU is probably a speed pitot. Tell tale are always thru the lower pan of the powerhead housing.
Model number should be stamped into a welch plug on upper aft part of powerhead. Year can be determined from that.
F_R
The cooling water indicator is the finger size hole in the backside of the midsection. Water droplets should blow out there any time it is running. It will blow a heavier spray when the thermostat is open. It is never a "water hose" stream. The thermostat normally cycles open and closed while running, so don't be concerned about that.
Johnson motors of the era have the serial number in two places, on a metal plate usually on the stern brackets, and a round quarter-size disc on the powerhead. They don't both just happen to fall off, so if they are both missing it probably is stolen. Experienced thieves know about the two locations. Amatures sometimes don't know about the round disc.
dcoon
Found a plug with this number on it:
J3671664
Is that it and what does it mean (size and year?)
wilde1j
Was on top, aft part of block? Doesn't look like a model no. to me.
