rmclaughlin78
- Aug 8, 2009
- 4
I am at a loss. Have had the powerhead rebuilt twice ($3400 for the first rebuild, second time under warranty) and same reoccurring problem. #1 cylinder burned through on exhaust side. Have had local shop check out problem, was charged over $700 and was told problem was fixed. Less than ten minutes in the water engine showed signs of overheat so we shut it down, pulled the head and the piston was burned through for the 3rd time. Also showed signs of weak water pressure and we have no thermostat installed. Of course, local shop won't stand behind their work and no one seems to have any idea why this is a reoccuring problem. Also reassuring, I have more knowledge of the Force repair manual than the mechanics that were working on the engine. Has anyone else run into this problem and if so, how have you solved it?
