Johnson shaft conversion question
evesdropper
I am looking at purchasing a long-shaft qd19 but I need a short-shaft for my boat. If I am looking at the parts diagram correctly, I can remove some parts and make it a short-shaft. Looks simple enough, but looks can be deceiving so I figured I would ask the experts here.
How much trouble am I setting myself up for?
From the parts diagram:
  1. replace driveshaft 305368 with 305318
  2. replace spacer 305552 with 305304
  3. replace shift rod - lower 305408 with 305319
Boat: Apache 12VS
Motor: 1958 Johnson QD(L?)19
Any assistance would be appreciated. Thanks.
Mike
evesdropper
Re: Johnson shaft conversion question
It appears I should have searched the forum archive. I found the answer to my orginal questions.
The bigger problem is, where do I find those parts?
None of the Johnson parts places I have found so far online recognize those part numbers. Most dont go back farther than 1968.
wilde1j
Try to find a donor motor for parts or try an outboard salvage yard.
salvage yards:
Trixie?s Landing, Bayville, NJ 732-269-5838
American Outboard www.americanoutboard.com
http://www.piratemarinesalvage.com/
TD?s list:
Salvage yards.
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
Superior Marine (800-338-9281)
evesdropper
Thanks for the tips. Not many marine salvage yards here in Omaha. I sent out emails and parts requests to all the places you listed. Hopefully something will turn up.
