Turning point props??
DACEAC
Just replaced my old 14X19 michigan wheel prop with a new 14.25x21 legacy prop from turning point. New prop with hub seems to be about 2 lbs. lighter than old prop. Definatly a noticible differance in performance. boat planes so much quicker. My question is does anyone have any knowledge on the turning point props?
n2ostroker
Re: Turning point props??
Do a search. You'll find plenty of users. Really good prop for the money and to be aluminum.
nlain
Unless you were severely under propped and engine rpms running way to high you may have to get them to swap that prop out for you, that 21 is going to pull like a 23P, you may not be able to get wot rpm with it. They are good props.
