i did it!! its alive w00t
coolguy147
ok i got a 1961 mercury 500
things ive done to it
clean rebuild carbs
replace impeller
change gear oil
new salnoid but i think old one might be good but i got used one for 10 bucks good though
ran new batter cables so i got 2 positives and 2 negatives
new coil condensor
clean and regap points
new plugs
helicoil third cylinder
readjust timing at the belt was off about 90 degrees
start it today abound 7-8 pm
ran great
only for a few sec cause getting dark
problem didnt see pumping water? any thoughts out of the hole in the back just blue smoke i saw:(
milehighboater
Re: i did it!! its alive w00t
I wouldn't worry too much for the time being about the water. It can take mine up to about a minuite to get water comming out of the engine. Congrats!
coolguy147
hopely u were right. i didnt even run it long enough for it to warm up enough. i guess when i went back and ran the motor around high idle it was about like tiny 2-3 drops on my hand but again hadnt ran the motor that long check out 2moro ill continue to pour water on head make sure it doesnt boil off
corm
Hi,
Only a mist will come out of the idle relief hole in the back of the engine.
The tell tale hole is in the bottom of the lower cowl. I am sorry I can not remember which side it comes out on. However you will be able to see it under there. You should be able to see the stains around it. Use the trimmer string method of trying to unplug it. I won't be going out to my engine shed for sometime other wise I'd take a picture of it for you. Milehigh is right about it not showing a stream for a bit.
Iandayen
it is a tiny hole on the bottom right side of the upper cowl.
It's not a large stream of water and it doesn't start for a minute or two (at least on my 68 500 thunderbolt)
coolguy147
i dont believe my motor has a tele tale. now theres a screw right above the exhaust plate i probably could add one
i was thinking the worse because something might be wrong having to flush water pipes of motor. clogged ports. water jacket clogged and stuff r these thing commmon i didnt run motor before i replaced impeller and i believe its like a fresh water motor
corm
Hi,
You have one. It must be pluged up.
coolguy147
Hi,
ya i found that out later where i saw water dripping out. its right under the exhaust. blew some compress air in there and it cleared it out not its pees real good. im really happy about this motor and plus its really loud but not annoying loud though dont really sound like a chainsaw i hate motors that sounds liek chainsaws or weedwackers u know the high pitch whine from 2 strokes:D
coolguy147
yeah i got one for problem though is my electric choke for some reason isnt working any thoughts?
and i got to go and adjust my idle speed
corm
Hi,
I have seem several problems with them. Mostly dirt or old dried up grease causing the plunger to stick. Also the plunger wire gets bent so it can not pull straight. If you have 12V at the choke wire connection then see if you have continuity in the choke sol. It is an electromagnet. They were pretty tough an did not fail very often. If they were overheated the nylon sleeve would expand and cause the plunger to stick. Then you could try a drill bit to open the hole up to allow the plunger to travel up into the sol. Do this by hand so you do not tear it up with to much power. Not a job for Tim the Tool Man. You would only be removing a couple of thousandths.
coolguy147
my plunger goes in there really googd. umm i dont think it was ever used. i believe the salenoid is ok condition workable.
i think something is wrong with my connectiion or the switch in the control box.
its weired cause i dont think theres anyways to take my wire off the salenoid. unless i cut it or take the wire off my salenoid
corm
Hi
Some of them have inline knife connectors covered with heat shrink or the wire went to a nylon terminal block before going into the plugin. You may be right on the choke button. The black button top mounted ones can be taken apart and cleaned. The one mounted in the side of the control box (depending on which box you have) can not be cleaned. They are hard to find these days.
coolguy147
Hi
ya i mean i get nothing when i press the button i guess ill check he voltage to the salenoid hopelly i wont have to take the control box apart cause i hear the insulation in the box even though its been away from the weather was really bad.
i have the button where its mounted on the top of the control box. whats he nylon terminl block before going to the plugin? is that to the choke salenoid?
whats hard to find these days? top mounted of side monted choke button boxes?
corm
Hi,
Your choke button is cleanable. It is just a copper cup that shorts across two
copper points under the black cap. Don't worry about the hard to find choke button, you don't have that one. Trace the choke wire back from the choke sol until you find a junction, if there is one. If you have a stud on the sol disconnect the wire from it and do a voltage test on the wire. It should be the same as your battery voltage.
coolguy147
ill check the voltage when i have time. i dont think there is a junction anywhere.
